Ouch,
ok let's observe the date, but more important, check that you do not exceed the maximum safe operating speed and always wear good gloves and goggles is the main answer because they help to prevent injury in the event of failure whether due to out of life or accidental misuse.
I read that organic grinding wheels have a shelf life of 3 years from date of manufacture. However there is no evidence of cause of failure here, the impression given that his injury is all to do with 'use by date' is a bit lame IMHO, if he wasn't wearing gloves.
DO NOT EXCEED is not for the date, it is for the speed rating which was 12,200rpm on the grinding disc (142mph peripheral speed on a 100mm disc). He only shows his hand and the grinding wheels so he could have been using it on a faster machine. If you use on a 10,000rpm machine it is far less likely to burst, if you use it at a higher speed then it could.
He didn't seem to show the date on the failed wheel if it was still there.
He didn't say anything about how it happened, how he was using it at the time, he could have been putting a lot of pressure on it, jammed it into a corner, caught a jagged edge in such a way that it would have failed whatever the date and especially so if he exceeded the operating speed.
I think all this safety stuff should be free, but -
1.
Booklet HS(G)17
Safety in the use of Abrasive Wheels (HSE)
(ISBN 0 7176 1739 4)(2000) (£7.00)
2.
Booklet L22
Safe Use of Work Equipment – Approved Code of Practice and Guidance on Provision and Use of Work Equipment Regulations 1998 (HSE) (ISBN 0 7176 1626 6)
Dave
