Ya, those JW Speaker ones are nice. But, during this testing and building faze, I can't justify buying the really expensive lights only to get them, and find out they won't work with the design I want.
On a production level, if I did build it specifically for the JW or other high end dot light, not all would want to have $1000+ of the cost of the front to go directly to just headlights. Best to leave that open for end user.
I have tested the 60mm Hella's though with a 6000k 55w hid bulb and ballast. It is retarded!! I could literally almost make out the Mars rover it is sooo bright. Plan to run a 3000k bulb in the high beam, which will be a touch more yellow.
After a week now of planning the new lights, I had a vision last night of the perfect set up, only to run to garage and find out yet again, it will not work and have center of beam at 22". I may have to settle around 20", which is where I believe they started out at.
