Scott Rowland
Guest
Finally today the phone stopped ringing and was able to get a couple hours in on car.
Parking brake lines finally mounted and cables inside car. My cables were not long enough so I had some other s.s. cable in the garage and tig welded some length on to them. After the weld I put heat shrink on the cables themselves to eliminate any chaffing to shifter cables and/or alum gas tank. Now, time to decide on handle location and then I gots some stops!
riv-nuts into alum and fastened bracket. Should be very solid. Shifter cables are tight as a guitar string right now, so will be remounting shifter. Looking at the later model chassis, I will be redoing some of the bars inside of the cockpit to make better mounting position for shifter and more room for center console and dash layout.
