SPF window screws
My window screws are starting to rust a bit. I'd like to replace them with stainless. As far as I can tell they are #6 3/8 long sheet metal screws with a flange and phillips head. Mcmaster Carr or the Ace Hardware down the street don't have them. Anybody know where I can get a box.
Seymour Snerd
We're talking about the ~15 screws that hold the side windows to the doors?
I did the whole plastic screw with rivnut thing, so have to rely on memory, but....
Flange? I could be wrong but I thought my original screws were "oval-head" as in flat-head that is a little domed. Or maybe that they were pure flat-head. Are the holes in your windows not counter-sunk for flat-head screws? If I'm right about the head and you're right about the size, McMaster has them: 95639A322.
I also thought, but again could be wrong, that mine were straight, not phillips. And furthermore, I remember them being longer than 3/8", except for a couple that were hand-shortened so a not to punch through the door frame (don't know why rather than use shorter screws, but that's different question).
I'm puzzled.
These are the screws holding my windows on. They seem to be a mixture of 3/8 and 5/8 long. I'd like to replace them with stainless. Any help would be appreciated.
Steve C
Steve
Rich,
Screws you show are not what SPF uses; someone changed them.
SPF supplies slotted head SS screws that are countersunk into the plastic.
Steve P2125
Seymour Snerd
These are the screws holding my windows on. .
Those look to me like what is normally sold as an upholstery fastener. I've never seen them in stainless even after a fairly thorough web search.
I think the McMasters equivalent would be the "Wide Washer Head Phillip" but no stainless version is listed. Interestingly (to me at least) they have a "Round Shank Screw for Brittle Plastic" which combined with a stainless washer would hve the same effecty, and from a thread perspective is probably ideal (eg 97349A200) and they have it also in flat head in case you want to use the countersink (eg 96068A153, but not in 3/8").
I can see the appeal of the flange or washer head screw; less worry about cracking the windows.
IAE I don't see anything else that's much closer.
I have the same Phillips head screws as Rich on my windows. My headlight cover screws are the type Steve noted. Surprised Ace doesn't have something close.
Rick Muck- Mark IV
GT40s Sponsor
Current side window hardware is the black pan head screw. The plex for the side glass is not currently beveled, but could be done so with a countersinking bit.
The rivnuts and either nylon or stainless machine screws is a good way to go if you anticipate removing the side windows with any regularity.
Steve C
Steve
I like the original beveled screws and countersunk plexi (makes for an easily cleanable surface).
Seems like SPF went to no countersink and pan head hardware to preclude stress cracking the plexi if the screws tightened too much.
I eliminated the possibility of cracking by putting a drop of glue on the screws and tightening with my fingernail...No plexi cracking and easy to clean.
Steve P2125
Jack Houpe
I considered using those rubber expanded nut things, can't remember the name of them, they are used on motorcycle windshields. They would serve two purposes, one to secure the window and two to help with the expansion and contraction due to temperature changes which causes cracking.
Rick Muck- Mark IV
GT40s Sponsor
Rubber well nuts. They have the steel threaded insert inside a rubber "hat". When the screw is inserted into the well nut it pulls forward and bulges the rubber thus retaining the well nut in the opening. Safir used them on the MK Vs to retain the seat backs to the bulkhead.
Steve C
Steve
Alan,
Won't the Rubber-Insulated Rivet Nuts be too deep for the top holes and don't they have a shpulder that will keep the plexi away from the frame?
Steve
Seymour Snerd
Alan,
Steve
Probably. I was just providing the reference in case anyone wants to use it. I still think rivnuts and nylon screws are the way to go, unless you're never going to remove your windows.
When I did that to mine I was also envisioning being upside down and wanting to be able to push the windows out for escape purposes, and feel more comfortable with nylon screws from that perspective. OTOH, the original arrangement (self-tapping in fiberglass) will probably push right out as well.
I don't recall who it was right off but someone here bonded all their lexan in place and it looked great..
Eglitom made some special pan screws with small rubber O-rings for his car and I believe he offers them for sale as well..
My reasons for wanting the change are two fold. After looking at the original 1046 it looks like all the screws around the windows are a brighter metal than the black I have and I'd like not to worry about rusting again.
Rivnuts aren't a bad idea but I'm not sure how often I'd be taking the windows off/on.
