I've purchased mirrors and I want them painted professionally.
Does any one know a source for the various Superformance paint codes.
In my case, I need it for titanium.
Thanks.
Thanks.
My MKI is titanium as well. I know I have the paint code here somewhere. I believe it's the same PPG titanium as used on the Lamborghini's. By the way, you should have received a tin of the exact same batch of paint used to paint your car. It's way more than enough to do your mirrors and still do paint chips for years to come.
This should give you the info you need. :thumbsup:
An easier to read version of this will go into the "How To" section of GT40s.com for reference
Hi-Tech Paint Formula Information
This document contains a collection of Hi-Tech paint formulas used to paint many of the Hi-Tech products including the Mark III, Coupe. Gt40.
Warning and Disclaimer: These formulas are to be used only by a professional automotive paint specialist with the capabilities to custom mix and match automotive paints. These formulas are representative of color standard for each color. As any paint professional knows, these colors may need to be tinted for an exact match. Spray technique plays an important role in matching metallic paints. Superformance and its Dealers accept no responsibility for the real or perceived correctness of these formulas. There are paint professionals capable of matching these colors and it is solely the responsibility of the vehicle owner to seek out a reputable painter. All of the following formulas are based on the PPG Global paint system unless otherwise noted.
Note: All paint formulas listed are in grams per liter, exactly as stated from the factory.
The use of Formulas
Many Hi-Tech colors are custom mixed using the formulas given here. If a paint code is given, this indicates a production a formula was used. Since Hi-Tech uses the PPG Global system, the exact color may vary. In some cases, certain toners may not be available in the US or have become discontinued in this case electronic color matching (scanning) can be an expectable alternative to the use of these formulas.
Cars 1 to 200
These cars were painted using Spies Hecker Paint. The paint technology used to paint these chassis is no longer available. If a chassis has to be repainted, it should be taken to a reputable paint specialist for custom color matching.
Sun Set Red D775 463 D955 214 D799 148 D793 72 D773 36 D740 17 D807 891
Lamborgini D956 649.1 Orange D744 883.6 D792 933.4 D953 974.6 D745 976.5 Amulet Red /Amulettrot 2CT (manuf.VAG) D752 Red 535.8g 535.8g cumulative D774 Bordeaux 414.0g 949.8g D753 Basecoat White 7.3g 957.1g D756 Blue Black 1.2g 958.3g D807 Medium Thinner 890.9g 1849.2g
PPG Paints Two Stage Colors Color Paint Toner Grams Per: 2 Liter Laser Red First Stage (Code D793 626.0 FRDM6688A) D953 769.0 D757 888.0 D773 934.3 D752 952.7 D775 960.1 Laser Red Second Stage D941 867.0 D775 905.5 D746 920.8 D752 9240.6
Fill damage with spot putty
Prep area for prime.
Prime with PPG 839 primer.
Prep for paint
Paint area with Coast Coat primer. (Mist coat)
Wheel Paint, Dark Silver (Anthracite)code is BMW 871 PPG #303712
Custom Ordered Colors
Audi Imola Yellow PPG #84479
Black Lava Red PPG #CHR ZMG
Dark Silver PPG #303712
Estoril Blue Metallic BMW PPG #190050 Ferrari Blue Mirabeau PPG #906275 Ferrari Grigio Titanium 2004 Ferrari PPG#36801 Ferrari Silverstone Girigo FER.740 Ford Matador Red Metallic PPG #5824 Lexus White Gold PPG #5758/2 Lotus Laser Blue Metalic #B85 Midnight Blue Pearl PPG #902694 Peugeot Recife Blue KMF Velocity Red Code27A ’05 Mazda MX5 Lotus Krypton Green Mono Code B109, Manufactures Code X1388
Hi- Tech Recommended Fiberglass Repair Materials Isophthalic Resin is recommended for any repair. Any supplier material can be used.
Chop strand mat in various weights can be used to achieve approximate 5mm thickness.
E.g. 225grms, 300grms.450grms or imperial measures 1oz, 1.5oz, or 2oz.
2700grms dry weight would give 4.8 mm thickness.
can someone point me to the correct paint code replacement for the indigo blue used by Superformance, PPG no longer supplies these products or a replacement?
Thank you, however, I do not know what the D numbers toner brands are?
or what is a p2120 spf MKII.
can you tell me what supplier to use for these toners?
My car is serial number P2120...one of the first batch of Superformance (SPF) GT40 cars made. It is Indigo Blue with Viper Steel Gray stripes. It is a Mark II (MKII) version of the GT40.
Google Ditzler paint codes, I have found other paint brands color codes. I went down to one of the paint stores (SW) and they could not or would not tell me what I wanted to know, a little Googling and I found it.
