Superformance guys,
Would appreciate if someone who believes their A/C operates OK would conduct a simple test for me.
I'd like to know what the dash outlet temp is under the following conditions:
A/C switch on, Recirc off ( recirc switch light off and sure outside air coming in through the NACA vent), all air out of dash ducts (not floor or demist or a mix), engine at 2,000RPM, and fan blower on lowest speed.
I'm getting 52F but, am told should be 40F or so.
My elex all working OK and Freon charge seems OK so only thing I haven't tackled is adjusting the thermostat. Has anyone set up their own A/C and if so did you adjust the thermostat and what proceedure did you use?
Thanks, Steve P2125
Thanks, Steve P2125
