Hi Russel, well that all depends on the tyres , cross plys as on the mk1 i run 1/2 deg neg camber, with 2mm toe out and 6 deg caster. the rear from memory has 1mm toe in, 0 deg camber. if i was running radials i would run a little more camber, the amount determined by tyre temps.
hope that helps mate.
kaspa
kaspa
