I was out looking for supplies for our spring cleanup and yard work. It was near a NAPA store, so I stopped in to see what they had for my 351. Told them what I needed and that it was for the square ports. They came up with a FelPro set of exhaust gaskets. They are the aluminized variety for the 98-69 engines. Took them since they didn't cost that much. As you can see they fit pretty well.
Trimmed them and had to do a little modification of the tubes so the new 3/8ths wrench would fit. Had to do a little grinding on the wrench, but it worked. Added thread locker to the studs and waited til this morning to attach the pipes.The gasket moved the pipes a little. The same sided pipes were moved out, and the crossovers moved closer in. So the pipes had to stay loose to get the merge collectors in place with a rubber hammer, then tightened the flanges down. The first heat cycle will probably fix their shape.
