The transaxle cooler (Earls) came with -10 fittings. However, from looking at the Ricardo, it looks like in the in/out of it are -8. should I just use -8 hose from the transaxle to the cooler, or should it be -10? I'm not really seeing the point of routing the -10s since I get drawn back to the fact the in/out on the transaxle itself doesn't appear to be -10?
edit: Unless I'm mistaken the Setrab units for F-GTs use -8?
edit 2 : Also, does the orientation matter? For example, if both in/out fittings are pointing straight up, is this the same as if I turned it 90* so 1 fitting is at the bottom, 1 fitting is at the top? (I believe the later option is better?)
