Hi Fred W,
110mm is correct.
Russ N,
I am with Frank C
listen carefully to what Frank C has to say, he is not the only one to explore high KPI. BUT, every thing else has to match. It can have some benefit. I have played with it as has some others, Frank c probably has played with it more than I have.
It is all about what the wheel / tyre is doing in the turn. what is good for one car may not necessarily be good for another. You need to remember that this forum is about 1965 model cars.
High castor does not necessarily cause high steering input if the KPI is matched to it so that you dont jack the car excessively, however, saying that some cars/tyres do benefit from loading the front O/S tyre by some jacking of the front end in a turn.
If You look carefully at some of the F1 and high end sports cars you may also note that the axle centre is ahead of the king pin axis. Just think about that for a minute and draw a force diagram, also bear in mind the high down force that the modern era experiences!!
What is unknown about Ross N's vehicle is the roll centre heights from front to rear and the mass transfer front to rear, this knowledge is fundamental to achieving good handling and good steering response. He could have a massive mass transfer. He has not got ( or posted) known wheel behaviour on a wheel aligner.
There is no tyre temp data - basic requirement, there is no tyre press rise data also a basic requirement. What is the LSD breakout torque , what is his engine idle speed-- how much trail braking does he use (if any) too much unknown stuff.
I am not familiar with the RF front suspension but if the rear is any indication well........
These days 3D software does it for you and 3D mechanism dynamics tells you everything in terms of kinetics. I have long since abandoned the pencil and paper method. I have made the offer before and some forum members have taken it up, provide me with your XYZ coords and I will do a 3D plot FOC.
dont laugh but I have applied racing car suspension theory to trucks buses miniing trucks and mobile cranes-- the saving in tyre wear was worth the effort!!
" Ackerman chosen to make the car easy to push around the pits "
Thats what they have engines for.
