AK SPORTS CAR GT40
Jerry, as Morten suggest it, the aluminum plate is a good option, the time to go to the test... When I bought my unfinished car in Belgium, she was coming from UK and was "almost" ready for IVA check. The back window was replaced by a aluminum plate with stiffeners (small bends in the aluminum sheet).
Jerry ...... thank you for your report on the IVA Fail. I obviously feel for you, particularly with regard to retest timescales and locations.
One of the reasons I'm thanking you is because hopefully others who are mid-build will read your post and realise that a fail can be achieved on very minor points. Insufficient bolt showing thru a nut is a classic. If it makes you feel better my car failed twice on real nit-picky points.
I'm concerned about your rear glass, particularly as you're going to a different test centre for the re-test. If it were me I would discuss this with them before travelling all the way to Exeter. The inspector would be correct to issue a fail for it not being correctly marked.
You are so close now, so keep your chin up and keep the updates coming.
Steve.
I think i am not going to risk it and go for correct marked glass or correct marked plastic....tooooooo risky with paperwork expalnation.
I like Jean-Marc’s suggestion. Perhaps find another inspection station?
That’s what I would do here in the USA. We’ve had the same or similar issues with other items not possessing to appropriate DOT marks.
I’ve seen people inspect cars with Trailer Lights in the rear and the original lights disconnected. Similar with mirrors and even windshields that were exchanged later. The inspectors don’t necessarily have to see a quality fit and finish in the cars they inspect here - just that what they are inspecting meets the letter of the laws.
jerry with the seat bolts can you reverse them with button heads and have the nuts inside the car nothing protruding?
thought of that but bolts / nuts are visible inside car ( im using adjusable runners. )
so have replaced all with longer bolts so at least bolt dia is showing. ( will trim down after IVA )
As i am trailering car I dont want to go more than about 100 miles. so that limits me to 3 test stations. 2 are in end of August so not really much choice....All iva centres work to the same check list...
Jerry
I have now sent off a template of the screen to company called ACW Motorsport Plastics. who are able to produce in polycarbonate and give it an E mark...
So lets hope that puts that paticular FAIL to bed...
Jerry
Steve Dean
Hi Jerry ....... good to see you are on the case. The suggestion from Randy V was well intended BUT given you are submitting the car for a re-test then the inspector will be specifically looking at the points that were a fail. Mike Pass, who frequently visits the forum mentioned to me that there was a company that would produce a Polycarbonate rear window. Presumably they could also do side windows. I wonder what the cost would be as that could be a path for new builds to follow. Although I guess the grief comes with being able to adjust the mirror from the drivers seat.
I'm pleased you're nearly over the finish line. All the current political talk of us re-joining the EU would completely kill the UK kit car industry.
Hopefully you can spend the autumn, following an IVA PASS, completing the car as you want it and before you blink the Spring of 2027 will arrive and you can get out and burn some rubber ....... not toooooooo much as we know the cost of rear boots !!!!!!!
Steve.
