850 QC transaxle
You can do that by adding a bolt-on bracket using the top bolt holes. The bells are integrated into the case.
Taking egomans suggestion a step further..... why not a boss or mounting eye on the top of each sideplate, as in Hewland and others? Makes hanging the trans off the chassis real easy!
Also the rear bulkhead can be replaced with a P*rsche-style rubber-donut nose mount for chassis that integrate that feature.
I see the reasoning of the smooth sides being easier to cast but wouldnt ribs make it stronger with less weight?. I also noticed that you have allowed for there to be 2 access panels on either side of the gear box. Are these for assembly ease or will this allow shifting to be accomplished from either side.One other thing, if you cast in some bosses to allow for the mounting of inboard brakes it would make the transaxle that much more useable.If the bosses on the bells are for this then disregard.
The Ford GT Ricardo Ratios would be perfect for me... unfortuneatly the Nice New Ford box wont fit my car.... and it is a tad to heavy IMHO
This is a better comp.
<TABLE style="WIDTH: 242pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=323 border=0 x:str><COLGROUP><COL style="WIDTH: 48pt" span=2 width=64><COL style="WIDTH: 50pt; mso-width-source: userset; mso-width-alt: 2450" width=67><COL style="WIDTH: 48pt" span=2 width=64><TBODY><TR style="HEIGHT: 15.75pt" height=21><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 48pt; BORDER-BOTTOM: #ece9d8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" width=64 height=21></TD><TD class=xl67 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; WIDTH: 48pt; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent" width=64>Ricardo</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 50pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=67></TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 48pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=64></TD><TD class=xl67 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; WIDTH: 48pt; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent" align=right width=64 x:num>960</TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl67 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" height=21>R&P</TD><TD class=xl68 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: #ffcc00" align=right x:num="3.3639999999999999">3.364</TD><TD class=xl65 style="BORDER-RIGHT: black 1pt solid; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent" colSpan=2>Total Final Drive</TD><TD class=xl69 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: #ffcc00" align=right x:num>3.90</TD></TR><TR style="HEIGHT: 15pt; mso-height-source: userset" height=20><TD class=xl63 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 15pt; BACKGROUND-COLOR: transparent" height=20>1st</TD><TD class=xl70 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num="2.6110000000000002">2.611</TD><TD class=xl64 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num="8.7834040000000009" x:fmla="=SUM($B$2*B3)">8.783</TD><TD class=xl64 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num="8.8841999999999999" x:fmla="=SUM($E$2*E3)">8.884</TD><TD class=xl70 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num="2.278">2.278</TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl72 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 15.75pt; BACKGROUND-COLOR: #ffcc00" height=21>2nd</TD><TD class=xl72 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: #ffcc00" align=right x:num="1.708">1.708</TD><TD class=xl73 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: #ffcc00" align=right x:num="5.7457119999999993" x:fmla="=SUM($B$2*B4)">5.746</TD><TD class=xl73 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: #ffcc00" align=right x:num="5.6861999999999995" x:fmla="=SUM($E$2*E4)">5.686</TD><TD class=xl72 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: #ffcc00" align=right x:num="1.458">1.458</TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl70 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" height=21>3rd</TD><TD class=xl70 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num="1.2330000000000001">1.233</TD><TD class=xl71 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num="4.1478120000000001" x:fmla="=SUM($B$2*B5)">4.148</TD><TD class=xl71 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num="5.226" x:fmla="=SUM($E$2*E5)">5.226</TD><TD class=xl71 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num>1.340</TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl72 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 15.75pt; BACKGROUND-COLOR: #ffcc00" height=21>4th</TD><TD class=xl72 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: #ffcc00" align=right x:num="0.94299999999999995">0.943</TD><TD class=xl73 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: #ffcc00" align=right x:num="3.1722519999999998" x:fmla="=SUM($B$2*B6)">3.172</TD><TD class=xl73 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: #ffcc00" align=right x:num="3.0693000000000001" x:fmla="=SUM($E$2*E6)">3.069</TD><TD class=xl72 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: #ffcc00" align=right x:num="0.78700000000000003">0.787</TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl70 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" height=21>5th</TD><TD class=xl70 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num="0.76700000000000002">0.767</TD><TD class=xl71 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num="2.5801880000000001" x:fmla="=SUM($B$2*B7)">2.580</TD><TD class=xl71 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num="2.3828999999999998" x:fmla="=SUM($E$2*E7)">2.383</TD><TD class=xl70 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num="0.61099999999999999">0.611</TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl72 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 15.75pt; BACKGROUND-COLOR: #ffcc00" height=21>6th</TD><TD class=xl72 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: #ffcc00" align=right x:num="0.625">0.625</TD><TD class=xl73 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: #ffcc00" align=right x:num="2.1025" x:fmla="=SUM($B$2*B8)">2.103</TD><TD class=xl73 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: #ffcc00" align=right x:num="1.9889999999999999" x:fmla="=SUM($E$2*E8)">1.989</TD><TD class=xl73 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: #ffcc00" align=right x:num>0.510</TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl70 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" height=21>rev</TD><TD class=xl70 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num="3.1349999999999998">3.135</TD><TD class=xl71 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num="10.546139999999999" x:fmla="=SUM($B$2*B9)">10.546</TD><TD class=xl71 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" align=right x:num x:fmla="=SUM($E$2*E9)">0.000</TD><TD class=xl70 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD></TR></TBODY></TABLE>
DeLynn
What kind of engines can the 850 QC transaxle be fitted to?
Go to the website for Griffin gearboxes and you will find information there. You can call Delynn and ask him. I know they will have bellhousings for both Ford and Chevy small blocks.
