I spent a lot of time getting the door fits just right. I had to relocate of the ball studs on my lower hinge mod because the location was too far aft. The left side door hinge operation was flawlwss, and it turns out location of the ball stud on the left side was much farther forward. I moved the right side forward to match. Problem solved.
Next I did a test fit of the windshield. Wasn't pretty. Long story short I realized the body was not matching the glass. A portion of it was the windshield flanges were too long. They were intentionally left this way for strength. So it was time to cut them to size. But the windshield was much wider than the car. And I haven't done anything to the body to fit the doors or hood. Pretty much tweaked it for the tire flushness but it's not under stress. Well, to get the body to fit the glass I had to spread the body. I used a pipe clamp then screwed the body into position to hold it.
I had to move the existing holes a bit. But this illustrates how much movement I got. Right side had the same movement.
The glass was good to the A post, but now it wouldn't set down properly in the front. So I marked where it was hitting and ground the flanges
After all that, the glass fits like a glove. It's just sitting loosely in place:
Problem is, as you might imagine, it threw off my hood and door fits. So back to square 1 on those. On the bright side, I'm getting better (faster) at getting the fits the way I want them!
I also did a trial on painting the door handles black (hanging in the pic). I was pleased with how they came out so the upper hinges and fuel door assembly are next. For anyone interested, the purple can is what I used
One more issue, I can't get my rear wheels centered in the wheel well any better than this:
Is this common? The front wheels have a bit wider gap to the hood in the rear of the opening than the front. I'm pleased with the look, but the body is cheated as far back as I dare. I have the rear clam under a lot of tension trying to force the rear hinge aft to open up the gap to the tire, but that winds up pushing the clam up, causing a V margin on the gap to the spider alon the side. I also raised the hinge mount point because the virtual center of the wheel opening was lower than the center of the wheel. But once again, that opens the gap to the spider. By the way, this picture was taken before spreading the A posts for the windshield. That didn't have much of an impact on rear fits. I think this is as good as I'm going to get it, but I figured I'd check to see if I'm missing a trick or something.
A.J.
