Chris Duncan
Got some scales and some floor tiles as slip pads and trying to adjust corner weights with the coilover height adjusters. Was wondering about the math.
It's a given that front to rear weight split is about 40/60. But what happens when the side to side weight split is not 50/50. Let's say you're tuning with driver weight with LHD, or you have the battery off center, or the steering column and wheel weight.
So starting with a 50/50 side to side, 40/60 frt/rear with a 2200 lbs car
LF 440 RF 440
LR 660 RR 660
and adding a 140 lbs driver on the left, should the correct weights be
LF 440 + 40% of 140 (56) = 496 RF 440
LR 660 + 60% of 140 (84) = 744 RR 660
or
LF 496 RF 440
LR 744 RR 660
so the end result is that the percentage difference front to rear is the same on each side
496/744 is a 40/60 split
and
440/660 is a 40/60 split
this is just for example because you know some of the driver weight load will go to the passenger side
I'm just thinking that all your trying to accomplish is to remove diagonal twist/loading or "wedging" as they say in the stock car world. And by the math that means each side should have the same percentage split even if they are different in total weight.
Hope this is a little clearer than mud.
LF 440 RF 440
LR 660 RR 660
or
LF 496 RF 440
LR 744 RR 660
and
