I'm not much of a believer in twin plug ignitions as being the solution for problems with high compression motors. Anecdotal for sure, but my friend Ed rebuilt his Porsche 911S (early model, high compression, has been rebuilt a number of times) two years ago and went to a twin plug ignition. Other than lightening his wallet a lot and causing some headaches, Ed reports no difference in the running of the motor. I know that goes against all Porsche lore and knowledge gurus in Porsche land, but Ed is used to that dealing with the Porsche crowd.
Ford evidently does believe in twin plug ignitions, but for certain applications and reason that is a bit different than cited here. I've been researching new trucks and started reading about Ford's new (for 2010) 6.2L gas motor. It uses a twin plug ignition and one of Ford truck forums had the lead engineer for the 6.2L on the board for an open question and answer session.
The thread is long and located here:
Ask the engineer for the new 6.2l gas engine! - Page 4 - Ford Truck Enthusiasts Forums
But some of the posts, like #55 and some later ones, talk about why they went to the twin plug solution.
From Mike the Ford Engineer:
But here goes. It has a large bore. It has a large bore to enable larger valve area and reduced stroke, to be able to increase the engine speed to meet the power objectives.
It needs 2 plugs to burn the charge on a timely basis. You need to burn the charge relatively quickly because the longer it is in the chamber unburned, the more heat the charge picks up from the chamber and the more knock (detonation) limited you are. If you increase charge motion (tumble/swirl) the time to burn the charge reduces but the charge picks up more heat from the chamber (higher charge motion leads to higher heat transfer), so you again end up being more knock limited. Adding charge motion via swirl or tumble also reduces port flow coefficients so horsepower is reduced.
Twin plugs and a high flowing port was a good solution for this engine we feel.
The compression ratio is also a fuel economy compromise between unladen and laden (or towing) driving with regular gasoline. If you go to too high a CR, it's great for city driving, but when towing a trailer the spark needs to be retarded too much to avoid knock, and fuel economy suffers.
The components in the engine are typically designed with an adequate safety factor to the specific application. If there is a redesign to improve performance then all the parts get looked at and re-designed to ensure durability and reliability.
Ford uses the twin plug ignition system to increase knock tolerence, as mentioned, but it also lets them run a bit more timing resulting in a bit more torque (power). This motor only has a 9.8:1 compression ratio, certainly nothing out of the ordinary these days.
So, it may very well be the power increases cited by by the twin plug aficionados is more about maximum timing the motor will withstand, a direct consequence of the twin plug ignition.
due to the fact that the plugs are going to fire a few degrees prior to TDC,
I hope they fire more than a few degrees before TDC, more like 30-40 degrees BTDC, otherwise that will be one poor running engine!
