An interesting thread indeed! for my 2c worth, I've only driven one GT40 rep (my own) & found it soft & vague. Straight line stability is very poor, altho it'll hold it's line in a corner, ie it's better when you lean on it.
Altho I haven't taken it on a track, at my local roundabout (in the wet!) I've found the car neutral to oversteer (which I like) & put this down to the weight distribution. (including driver, fluids, air-con, etc f-r dist is 44.5%/55.4%)
After a basic geo check, camber & track are ok, so I can only assume the vagueness & wandering is caused by bump steer, & poor aerodynamics. The suspension pickup points are quite different from side to side & this suggests to me there was a lack of accuracy when the chassis was originally jigged.
This the main reason I've chosen to go for rose-jointed suspension & I'm prepared to suffer a loss in ride quality to get accurate geo. I feel this is especially relevant for 17" wheels.
I believe I can improve the aerodynamics with a new nostril & some ally panelling but only time will tell if I'm right.
I agree with Chris's comments re fitting a roll cage. I've almost finished fitting the front cage & am very happy with the amount of strength & stiffness it'll add to the chassis. Again,it's a compromise against weight, but I've made my own decisions!
I believe the other main area for improvement on my chassis is the height of the engine/gearbox & this is another issue I hope to address.
Having ridden in other reps I think my car is a bad example & I'm confident that after my re-build & re-spec it'll handle *much* better.
So to summarise, the basic 'standard' package from *my* replica manufacturer is *OK*, but can be improved, if you have the time/ability/money etc!!!
