My GenII Viper had dual TB's, so the concept is not new or custom. I haven't heard of restriction problems with the FAST setup. Which FAST intake and TB combination?
All Fast intakes are designed for torque in the 2500 - 6500 rpm range. For someone looking to make absolute max power, single plane manifolds will allow better breathing and hence more horsepower, above 6.5K rpm. But the tradeoff is 20-40 ft/lbs of torque in the midrange.
I haven't followed carb technology so perhaps I need some further education. I was under the belief that although you do indeed gain the HP over TB's/EFI, this may not be the best for the lateral G's of the track due to float bowl surging and resultant starvation. True, I haven't had a carb'd car since the early 70's so I'm relying on very old data.
Hey Alex,
Do you remember Gross-Jets??
Beautiful, for sure.
Just looking a little closer, I notice the slip fit headers. I have always been of the opinion that those were a "no-no" on an injected engine. Especially if they are BEFORE the O2 sensors, as it appears they would be on this engine.
Probably just something put together for the show, but it's little details like this that many times I just have to smile about. I live by the saying, "the devil is in the details", or lack there of in many cases.
Crash,
I think that they are most likely using their "Double Slip Fit Collector" just for that reason.
Mike,
An FYI, one of the Semper Fi team said they raised about $40K at the 25HR.
Single plane intakes rely on a straight shot of air directly down into the manifold. Great if your car allows for a big airbox right on top, or ability to run a filter out in open (hopefully pressurized) air. But if you have overhead clearance issues, making air take a tight 90 degree corner down into the carb/throttle body will absolutely kill horsepower.
