David's Monocoque Build
2144-Panel Closing Rear Spare Wheel Recess. So far this is the only panel I have used the bead roller on , tipping die to make the lower flange and the shrinker stretcher to curve the panel.
Hi David
I'm a newbie here and discovering your build for the first time... and Wow!!
It would be great to see your overall progress at some point, it must be coming together now?
Whats the plan with the other components? Powertrain and bodywork etc?
Dan
Hi David
Dan
Hi Dan
Sometime before the panels are welded together I'd like to lay them all out in somewhat proper position for photos. All this work takes longer than most people think, especially the first part to be made. Researching every panel looking for the perfect angle to see every detail.
Other components, I'll be making all that I can. I want to run a mild FE, transaxle not sure yet. As for body work it maybe a mix of fiberglass and aluminum.
It is a long project, I suspect 12000 to 15000 hours in all ( research, making hammer forms, jigs, building and so on ).
