After long debate and comparisons, I have decided to go the 1UZFE route for the build. (So I dont want any "shoulda gone with a ____" comments)
Picked up this from a local yard last week:
From a '99 GS400
T-belt changed @90k although unsure on overall mileage. Overall its looking like a well maintained engine all things considered.
Goal for SLC build: I want to go for a street-oriented build that may go to the track occasionally, but primarily street-oriented.
Goal for engine: I want to get it in top running condition but remain N/A. However, if cost effective I'd like to build in the ability to go mild FI down the road (6-7psi).
First order of business: The wiring harness is hacked up fairly badly, but I do have it and so I have 95% of all the connectors. Which route would everyone recommend?
A) Repair existing wiring harness and buy a stock ECU?
B) Buy new wiring harness and buy a stock ECU?
C) Go with aftermarket standalone and completely bypass stock wiring/ECU?
Second order of business: Maintenance. I am all about doing maintenance now rather than waiting for something to break and having to fix it later. Thus far I have this on my list to do:
-T-belt plus accessories (tensioner etc)
-Water pump
-Oil pump
-Valve stem seals
-Gaskets from the heads up (minus head gaskets since I dont think I will pull the heads)
Is there anything extra you would recommend or anything you would recommend I take off the list?
As mentioned in the title, I'd love your input :thumbsup:
From a '99 GS400
-Water pump
-Oil pump
-Valve stem seals
