I have a souped up chevy 350 engine in my GT40 (no snide remarks please!)
It has a Isky gear drive cam which means the cam runs counter-clockwise. To compensate for the this backward motion, the distributor uses a reverse drive gear to make it run clockwise.
The problem is that this setup causes the distributor to grind down the pickup coil - the plate that signals the main coil rides on the surface of the pickup coil and wears it down and eventually shorts it out.
I've been stranded once because of this, and was almost stranded a second time by a damaged pickup coil.
Anybody have any suggestions on how to solve this problem!
John
:blank:
John
:blank:
