Doug’s RCR Jaguar D Type Build.
Doug M
Chuck, good question. I live in West Virginia, and I’m sure things are a bit more relaxed than in other states. The certificate of origin from RCR ( or whatever it’s called- I’m not home to look at it) is a 1955, which by WV rules, means it’ll be grandfathered in like an antique even though it’s a ‘new’ car.
It does add another complication, but actually I spent more time researching and web searching for ideas and parts than I did installing it.
It was a great deal easier, too, since I decided to use bucket seats.
Where in WV, Doug?
Doug M
I haven’t posted in a long time as I’ve been busy with life stuff. But I’ve been making some progress on my build, and I’ve recently solved the door hinge problem that’s been plaguing me since last summer.
The RCR supplied door hinges were poorly assembled, especially the right side driver door. Not much was square and the holes didn’t line up exactly. Tried to make the hinges work, and they sorta did, but there was a good one inch of wobble and sag when opening and closing the door.
RCR’s suggestion to ream the bolt hole one size bigger didn’t help. After that, many calls and emails for an exchange went unanswered. I even made an offer to pay for a new set of hinges and got no response.
Explored a different hinge design, tried making my own… all fruitless endeavors.
Finally had a brainstorm and drew out a poster board template and took it to my local metal place. Solution was adding a 90 degree top part of the hinge to steady it out. 1/4 aluminum was probably overkill, but I don’t want to have to do this again in a few years with a completely built car.
So with some creative grinding for a good fit and experimenting with various washer thicknesses, it’s all back together and tracks perfectly with only a millimeter or two of wobble (which I can definitely live with).
So for those who are building this kit and have yet to get this far, feel free to use this idea if you like. I’m very happy with it.
Chuck
So for those who are building this kit and have yet to get this far, feel free to use this idea if you like. I’m very happy with it. View attachment 146857View attachment 146858View attachment 146859
Excellent idea, nicely done.
Doug M
I had originally planned to just go with a very simple cable setup to open the door latch, but I thought I’d borrow / blatantly steal from the Book of Chuck and try a better design.
If you’re also following Chuck’s build, then it’s very obvious that his work is more “Concours d’Elegance” and mine is more “Beyond Thunderdome”… I had some leftover aluminum pieces, so I fabricated a basic handle system that should go well with the old race car aesthetic once the interior is completed.
Unlike Chuck, I don’t have access to a mill, so to help reduce wobble and such, a stack of 3/16 x 1.25 inch washers were carefully reamed out with a 1/4 drill bit to create a tight fit with a 1/4 bolt. Also, some thin spots in one of the fiberglass doors made the attempt at artful minimalist latch mounting look like complete hackery, so I did it the easy way. Once the doors are finished, it’ll look just fine.
Hi Doug, I feel your pain about dealing with RCR about design inequities, after receiving my XJ13 kit I sent photos of all such things some very glaring issues like my door hinge pillars being welded upside down from factory. After waiting over one year for a steering rack they sent me some cobbled together unit nothing resembling what should have been. After many quibbles with King Mufasa you get nothing , you are on your own. After paying top dollar, in the end it is a slightly better kit car. You see how Chuck has completely reengineered his so called factory designed. These kits will test all your skills
Doug M
No doubt, Steven. I can only speak for the D Type kit. Overall, I really like it, but it is a prototype kit and compared to other kits with roofs and proper doors and such, the D Type is very simple and there’s not a whole lot to go wrong by comparison. Still, the issues have been challenging, but the D Type is my dream car and I’m enjoying the challenge of learning new things.
Doug M
While I’m approaching this Jaguar build like a 1:1 scale model, I’m doing my best to not get too over obsessed with some of the details… but there are a few details that I really want… the labeled knobs being a big one. I searched off and on for over a year and couldn’t find any modern reproductions of the D Type panel knobs I wanted, so I decided to try to make them myself.
I bought four Lucas SPB104 push pull switches which appear to have Bakelite knobs. I live in a smaller town where everyone knows everyone, so a friend hooked me up with their friend who has a funeral home with a very nice laser engraver. I was able to sit with him after hours at the computer and adjust and tweak what I wanted.
If you want to also try this method, I would suggest bringing a piece of scrap 2x4 with a hole drilled in it for the knob to be held in place. We ended up using a piece of foam that was lying about, but something more solid would have been easier. Also used a piece of painters tape to help center the knob with the red laser dot… something that can’t be seen on the Bakelite material.
These knobs are expensive, so a very very light test run was done. This etched only the tape and gave us an idea what adjustments were needed. Once it was locked in, the machine did 3-4 passes set at 100%. This gave a clean, deep etch.
Font used was plain Arial in all caps. We tried a test with Arial bold but it was too thick.
Very pleased with final result, especially after the white paint was applied.
A sample of the original knobs.
Chuck
Nicely done, and captures the look of the original.
Chuck
View attachment 147933View attachment 147934View attachment 147935View attachment 147936View attachment 147937View attachment 147938
Looks great, and vintage.
Knobs labeled are available from Moss. Here is a link to one of several options. https://mossmotors.com/knob-set-6-piece-set
But the Moss doesn't have all the knobs labeled that match what we need on the Jag D Type. Those really look good.
Doug M
Thank you Chuck. I had considered for a hot minute getting two of the ‘Head Side’ knobs and painting black over the word that didn’t match the switch function, but in the end I thought it’d look pretty bad.
Hopefully others will try the same method for their projects. The biggest hurdle is finding a laser engraver business that will let you sit with them and talk them through it rather than dropping them off and hoping they read all your notes.
Doug M
Bits of progress made as the summer progresses… slowed by a busy summer schedule and a lack of air conditioning in my garage.
While I thoroughly admire Chuck’s custom and authentic wiring method, I’m rather lazy and I enjoy modern simplicity. For my D Type wiring, I went with what I’m most experienced with, which is a ready to go wiring harness kit. I used a Speedway Motors 12 circuit wiring kit #91064017.
In order to go with my preferred ‘vintage appearance with modern innards’ method, I found a non functioning Lucas voltage regulator on eBay UK and gutted it.
The small fuse block secured easily to the passenger dash and some thick walled 1 inch square aluminum tubing from McMaster-Carr made perfect spacers to bring the whole dash surface an bit closer for a more proper look … basically a false wall type of thing. A raised panel was made using Chucks method, but my method included more salty language.
Ultimate plan will be to dress up the exposed passenger dash with cloth covered wire and the other assorted doodads, then aged and weathered to match the vintage appearance of the original, but will be nonfunctional and totally for show. In the event of a fuse needing replaced, the cover of the voltage regulator is easily removed with a small flathead screwdriver.
Chuck
Very nice. Fitting the fuse block inside the voltage regulator is an excellent idea. I am surprised if it fits so well.
Using the wiring kit will make the project MUCH easier. I am nearing the time to remove the dash panel so I can properly paint it wrinkle black and fear I may not have labeled a wire or two, which could set me back another year. . . .
Chris Kouba
You'll be fine Chuck, as long as you don't let the smoke out of the wires in the process.
Doug M
Thank you Chuck. I have full confidence in you. I’m actually close to painting the dash as well, but it won’t be until the end of the month. Definitely looking forward to seeing your paint method.
I had a few backup plans for a hidden fuse panel, but the 12 circuit block ended up being dumb luck.
Doug M
In the part swapping scene between the D Type builders, I was very fortunate to have Chuck offer me one of his earlier attempts at making the dash panel. Not sure what was wrong with it, but it’s beautiful and saved me a lot of time.
In my many years of working on old GM cars with one hand, I’ve grown to appreciate a very lightweight and easy to remove dash panel. Some pictures I’ve found of original D Types being restored or well done replicas being worked on, a common trend seems to be a panel with access holes just behind the dash (I’m sure there’s an actual term for it, but anyway).
With the body on, I made a dash support with access holes that allowed clearance for the backs of the gauges. I also drilled out access holes with rubber grommets for the wiring to pass through. I’ll probably use quick connectors for easier dash removal.
I made a two gauge pod much like Chuck did. I have both the dash and the gauge pod tilted back at a 7 degree angle. Still determining where I’ll put some of the switches and warning lights.
Also did a test fit with the replica Smith gauges just because I was anxious to see it.
Chuck
Looks great! The lip holding the top of the panel is an excellent idea.
Just curious, did you get the mechanical speedo or the GPS version?
Doug M
Thanks. I went for the GPS version since, at the time I ordered it, I wasn’t sure which transmission I’d be able to use. Just seemed like it solved a lot of short term and potential long term problems.
