Lynn Larsen
Lynn Larsen
All,
Since I haven't been posting in a while and some of you don't know me and I don't know some of you all that well, let me apologize up front if I sound like I am being condescending or stating the obvious. That is not my intention; indeed, a lot of my posts are directed to the future reader who may not be as experienced or knowlegable as many of you. I am not either! So, I try to answer/ask some of the questions, if I can, I might have (or had) as a result of the discussions.
Jac Mac,
I think you've pretty much hit the nail on the head. To my knowledge all of the very hipo flat tappets users cut a groove in them to oil the cam lobes (as do some solid roller lifter - Isky comes to mind.) Squirters to cool lube pistons/lower cylinders, which, I believe, is more of a concern with the piston speeds these stroker motors run with. Please correct me if I am wrong on this and does anyone think that the slower piston speeds of a shorter stroke rpm motor would lessen or eliminate the need for this?
Doug,
I would assume you're going with a solid roller cam to achieve the higher rpms that hydraulics just won't allow. I would highly suggest you take a look at Crower's HPPO (high pressure pin oiling) roller lifters. IMHO, this system is far superior to the groove technique (while the groove is far better than nothing.) I don't know your overall engine plan, but I might suggest that the design of the valve train might be more important than the bottom end. You can have the strongest bottom end in the world, but if your valve train won't let the engine get to the kind of rpms that will stress it, it will be, somewhat, wasted money.
On the rods, if you can afford them, might I suggest high end I beam type rods over H-Beam. I think you'll find most of NASCAR runs these as they provide far less rotating mass. As to TI products for racing you might want to try CV Products, a NASCAR supplier here in NC. 800-448-1223 or CV Products, Inc - Racing Parts, Titianium valves, belt drives. (In a quick search, I only found Ti rods for Honda B18B and B20 engines from, of all people, Eagle.)
With respect to the original question from Nathan-- lower engine placement with wet vs. dry sumps-- I am using an inverted Porsche transaxle which allows for, virtually, the lowest possible engine position in a GT40 replica. With the Armando (or Aviaid) type pan, the bottom of my oil pan is ¼" inside the chassis' bottom plane. I don't think there is any way to get the engine, safely lower than this within the limits transaxle position dictates.
Pat, spot on - glyptol. Thank you.
Lynn
Jac Mac,
Doug,
Lynn
