Fat Larry's GTR Build
Ok engine and trans back out for installing heat shield and wiring
So today i took a cue from Kurtiss and replaced my rear studs and finished replacement of the dust seals on one of my calipers and then it’s on to the heat shield on the fire wall
Almost done the heat shield just need to order more heat shield for the aluminum chassis supports
One thing I discovered rather quickly is once you take all of the pieces off the car your new 24 x 24 garage fills up fast i am use to this since most of the cars I have built in the past 40 something yrs were done in either a single car garage or a cramped two car garage
Ok so spent the day finally finishing the heat shield and put the sound deaden on the other sound of the fire wall now it’s on to running’s the ducts for the defrost and vents plus finish up powder coating more parts while I wait for all the electrical systems to show up
Ok so finally after about 2 months my Infinity Box System showed up today so on to wiring the car, I spent some time today detailing the engine and just waiting for my new Raptor Turbos to come in once mounted off to California she goes to have the Engine Management System installed and then Dyno to make sure everything is working properly before I reinstall for the last time. I also spent some time working on the center console which I will finish up with an aluminum bezel and leather or cloth boot
So I got a new oil pan and pickup tube from RMB Motorworks so I wanted to install before I send the motor to Calf and then back onto the wiring I tried to give the pan a little polish job the first pic is before polishing
Ok motor all set and ready to go to California for it’s new ECU wiring harness
Ok motor made it to Calf now just need to wait for the Dino time, started on the switch panels powder coated them and started to wire
Ok switch panels wired moving on to the other 500 things that need to be wired
Wiring so much fun there is only so much room for the fat man to get under the dash I thought at one time today I would not be able to get back out and my wife would fine me three days later.
Well still on the wiring making progress all I have left is the rear lights and the wiper system. Then it’s make it all look neat.
