So when I spoke with the tech at Summit, he was unaware of the issue with potential static build up in the teflon hoses. The website I referred to earlier talks about it the issue, but I wonder if it is a concern that warrants 3x's the cost for their hose?
This is from TechAFX:
First of all, if you are using PTFE (Teflon) hose to transfer fuel, you need to make sure the hose has a 'conductive core'. This is easily recognized as the inside diameter of conductive core hose is black--vs the off-white color of 'non-conductive core' PTFE hose. This is important as fuel is a non-conductor AND it generates a static charge as it passes through PTFE hose. The black color in the PTFE conductive core hose is actually carbon--which allows the static electricity to pass through the hose/fittings assembly to ground. Without that, the static charge builds in the hose, looking for a path to 'ground' to--not a good situation. All PTFE fuel hoses used on production cars are conductive because of this issue--TechAFX only offers conductive core PTFE AN hose.
Second, the reason rubber hoses are failing now is because the chemicals/additives being used in today's fuel are not compatible with rubber hose. The production car business has not used rubber fuel hose for over 10 years because they were aware of the issues with being able to handle these fuels--the aftermarket is just now realizing how serious this issue is and that the only solution is PTFE, conductive-core hose.
I know because TechAFX has been doing extensive development/testing in an SAE-certified lab of our PTFE hose assemblies vs rubber hose--and the results are dramatic. To see some of these results, check out the January 2011 issue of HOT ROD magazine...they used some of our testing results to support a story called 'When Good Hoses Go Bad'. One of the results of this work was the release of our affordable, home-assembled PTFE, conductive core AN hose and fittings line.
We had not planned on getting into this business--we are primarily a provider of OE-style QD fitting performance hose assemblies--but we felt a cost effective PTFE hose solution was needed based on our testing results, so we created an AN PTFE hose/fitting product line.
We believe fuel transfer requires the utmost in safety.
I think most of us would agree this side of the business saw almost no requirements change for many years. But it seems to be experiencing a dramatic shift in the requirements now--we believe the solution is conductive-core, PTFE AN hose.
Aircraft use teflon hoses and I have never heard this was an issue? Not to mention that the SS hose would be grounded on both ends?
