Frank's KVA Build
I haven't decided yet.
It's about 600 km, which is quite a long way to do on my own.
Would be great to go there in a Dutch/Belgium group.
i took the engine and gearbox out and cleand up the side pieces of the gearbox afte that sprayed them with primer.
also started with the startermotor hope to finish that this week
Made a new bracket for my startermotor one that fits perfectly on the bellhousing
Frank, nice job. I am guessing that bracket will clock the starter around the mount in just about any position.
Are you having clearance issues with linkage or other components?
The reason I am asking is I may need to do a similar part to clear my shift linkage.
Phil
Hi phil,
THE bracket on THE left is THE one i made and THE one on THE richt came with THE starter
But i can drill as many holes as i want and turn THE starter around in any position
With THE starter in this position i have no problems with clearence
started working on the alternatorbracket and the aircopumpbracket
Frank,
I am going to ask a stupid question that you may have addressed earlier. With you starter mounted under the engine block, have you checked to see if it will spin in the right direction????? Your starter looks like a Hi torque unit, like mine. If it is, mine mounts from the opposite direction(trans side), spins clockwise from the back to front view of the starter, and thus the opposite action of yours, unless you are mounting it on the other side of the engine?? Straighten me out. Is yours wired differently because of your mounting position??
Hi Bill ,
There is'nt such à thing as à stupid question.
Specialy if it's for helping.
Bit ro answer you
I don't know !
I did Order THE starter by frank specialy for this bellhousing so i think
It must be ok
Frank,
good to see you working on your car again.
When i will have some time left, i will visit you.
I reached the age of which nearly every body retired, but i get it more bussier then ever.
dismanteld my gearbox because i need to shorten the inputshaft and the splines,the reason is that my bellhousing is 13 mm shorter than the pantera bellhousing so as you can see on the picture i made inside the bellhousing that the shaft runs against the testring i made inside the crank
Frank:
I can tell you that going inside a ZF there is nothing like the quality of the machining and finish on gears and shafts, have fun.
Also I think that alternator bracket you are constructing is the Cats nuts, maybe when you finish it you might be so kind as to share the pattern. I am planning on using a standard V-belt on my motor.
Great looking work
Phil
hi phil,
yes the gearbox looks great inside i've shortend the shaft today on a lathe from a friend of mine.
next i'm going to make a hole for the drainige (or the cooling) at the back ,because the housing is empty so easy accessible.
And for the bracket i'll make a sketch for you.
frank
here are some pics of the progress on the gearbox
work on gearbox
did some work on the gearbox
Securing the diff turned out nice ,i had the tools for about four years and used them for the first time .
closed the openings witch were going to be at the bottem with npt plugs
Made a pressing tool for the taperbearings
Hé is still Alive !!
I ve been working on the car on and off now for some time now and thought that its time to post Some progress/satback here again
After all the work I have done in the past on the backend off the car I finally got to fit the engine and axles only to found out that my cluch lever got stuck in the horseshoe and the engine was 35 mm to much to the front which I could See directly on the axles
I tried to fix the clutch clearence but after Many hours and materials found out this didn’t work so ….. just cut everything off and start again !
I will post the progress in foto’s and explain them later
And more
And the last
