I've been doing some research on this and it seems the previous owner of my kit, Bob Lawrence, had posted a question to the Audi Fans mail list back in 2001 regarding the 016 transmission vs the 01E. Here's Bob's question and the reply:
<BLOCKQUOTE><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><HR>
I am building a replica of the Ford GT40 that raced at LeMans in the sixties.
The car is mid engined and is set up for the Audi 016 5 speed box that was found in the Audi 5000's and 100's. The trans is bolted to a 5.0 Ford V8 with an adapter plate. I am interested in using an Audi 01E five or six speed. Are the mountings and bellhousing pattern the same? Will the 01E handle more torque than a 016?
Way cool:
Ok, here's the scoop on the audi stuff.
The 0165spd is considered the beefiest of the bunch, the O1E the weakest. When Bob Dupree did the LT1Quattro swap, I looked into this quite intensely. The 016 is a common swap trans, the adapter is easily sourced, and it appears to be the *only* one that has been used reliably over the years.
For more on this swap, try going to:
www.flyinhead.com and following the links to the LT1Q.
It has the biggest input shaft of the group (save the v8, but that's only available as quattro, and is much bigger transmission all together), can handle the highest torque and hp of the audi line as well. One option *might* be to get the trans fluid pump off the v8 quattro 016 based trans (it's attached to the pass side driveshaft, er, that's facing the correct way - behind motor), and adapt it to work with the 016. I've heard from several audi race dudes this is an upgrade that can be done, but I have no btdt, nor know of anyone short of Audi sport that might have tried this.
Bottom Line: In the audi transmission lineup, the 016 is the strongest trans available, especially for a high torque 'merican v8 motor.
HTH
Scott Justusson
QSHIPQ Performance Tuning
<HR></BLOCKQUOTE>
[ January 29, 2003: Message edited by: Mark Worthington ]
