As covered in my build log, this is a replica of the grille set used on the Gulf spec ‘40’s. They are designed to fit the replica bodies from Tornado, Southern GT, GTD, KVA, GT Forte etc using a Mk1 style rear deck, however there’s no reason why they won’t fit a genuine ‘40
Laser cut from 1.5mm 1050 grade aluminium, they are then pressed using a CNC’d press tool to give the correct and consistent rolled edge on the openings. All mounting holes (4mm) have also been laser cut for accuracy, ready to be either riveted or screwed on. Final finish is your discretion; natural, brushed, polished or painted
I’m looking a £80/set plus shipping for the upper and 2 lower panels. I can also do the lower panels as a perimeter frames suitable a simple mesh if required for the same price
Andy
(based in Norfolk, UK, but will post anywhere)
Andy
