however if your brakes are too large they may not get to operating temp and have less braking force than a setup which is slightly smaller and reaches operating temp.
Trevor, I have NEVER had cars that were overbraked in terms of heat dissipation,(Edit:except my F Fords which were light, had skinny tyres and not much power!) I would love a setup that was inefficient due to low temps! At least that could be easily fixed in terms of softer pads, presumably.
In terms of bias it should be set so you get MAXIMUM braking front and rear.
Now maximum braking does not mean lock up, it means when lockup is impending.
And at that point I have found that the difference between impending front lockup and impending rear lockup is as little as, or maybe less than, half a turn on the balance bar, hence my contention that the effective difference in the braking performance is very small....However I guess I could be wrong and half a turn could be significantly large.
Never the less, I like my setup and have had good results from it over the years, including a few class lap records. But when I get my current car optimised if I have time I may play around with more front and see what happens.....
