Jimmymac & Alistair's Cars
re: Jimmymac & Alistair's Cars
On the shifter medallions what do you mean by early, also what determined what color was used? Did you have these made?
Steve C
Steve
Hi James,
Interested in the medallion.
Will you sell one with the black background?
Please advise by PM.
Thanks, Steve
JimmyMac
It depended upon which gear lever set-up was fitted.
I have rarely seen these on original cars, definitely not seen one on a MKII and only one on a MKIII.
The plum knob which was fitted to Lotus cars were the type used and some knobs were flatter on top with a larger medallion.
Translucent Ruby Red was the original colour for the cloisonne but I had the black ones made up because we fancied them on our washbasin taps in the workshop.
JimmyMac
The matresses are coming together nicely at the upholsterer.
We used nickel eyelets in a fire-proof ballon skirt material. The seats should be complete in a couple of weeks.
JimmyMac
Brand new Metalastik couplings
Thank You for posting the Metalastic picture. What great memories. Thirtyfive years ago I was introduced to the engineering splendor that is the Metalastic coupling by my little Lotus Elan. They would not last long and I got pretty good at exchanging them. On the first one I took off the steel band before installation. What a miserable afternoon that turned into....
These things are great in theory but I think my expenciences were repeated by many metalastic owners. And of course the gentle rocking of the car with the handbrake on. Back and forth as the rubber segments compressed and expanded :) Good Times.
JimmyMac
More bodyshell parts
JimmyMac
Steering Column
JimmyMac
ZF-0 & 1 Ancilliaries ~ Clutch slave, lever and gearshift coupling.
That lever was hand fettled by a friend of mine.
JimmyMac
Original specification Shafer bearings and Konis dated 1966 for the suspension.
Also the later Armstrong shock absorbers.
JimmyMac
Achievements this weekend.
We decided to fit the early slam catch brackets as shown at the top of the photo.
This is a much stiffer member because it also fixes to the inner bulkhead with the two vertical straps. The lower simpler design in the photo is an original bracket for later chassis numbers.
I assume knowing the guys that both are available depending on what chassis spec is specified. I know they have bent over backwards trying to replicate all the Mk.II mods.
JimmyMac
This is the preferred Mirage bracket fitted.
JimmyMac
The seat cross webbing is in.
This is made with the original drawings and materials and the vertical straps will be rivetted when the buckets are fitted.
JimmyMac
Spreader plates for the Metalastik couplings.
These need to be bevelled properly as shown in the second photo.
JimmyMac
There is not many of these about in this condition.
~ A matching key fob.
JimmyMac
Here is an original loom.
We are now remaking the rubber 5-pin and modern 6-pin wiring plugs and connector sockets (the dies and brass pins are compete).
JimmyMac
NOS 1967 Alternator & Original Bracket
JimmyMac
MKII - Wiper Motor Gear Train & Splined Shaft - 120 degrees
Stronger than the usual Lucas wire driven sprocket
JimmyMac
In addition to a pair of new ones, I managed to get five used Wiper Motors so did a bit of restoration.
