[ QUOTE ]
[ QUOTE ]
other day a dealer asked
"What about people who take their car to a track day, how will this affect the warranty?"..reply? "This IS a race car, don't worry about it!!!" /ubbthreads/images/graemlins/blush.gif
[/ QUOTE ]
Not doubting you, but how can they support this? I mean, REAL track time? How about the guy that takes the Eaton blower and overdrives it for 750hp? I'm doing the same in my Lightning now for 475hp at 14psi (did I tell you I like this truck?! It feels mid 12s already, we need this thing at Brighton) but if the motor blows and I ventilate the contents all over the street I can't expect Ford to cover it under warranty. How would the GT be different?
So, a fellow drives the heck out of the GT on the track, uses up the pads and rotors, are they covered? Breaks a half shaft in a little "off track excursion", covered? Ruins that nice transaxles' synchros speed shifting on the drag strip?
Ron,
The barkes are "wear and tear" items and as such are not covered unless defective. If you chip or overdrive the engine you have "modified" it and as such are not covered (more on that later) and an off-course is not covered so long as it is obvious that the damage was due to contact. What Ford says is that the car was designed for high speed, full on use and that the warranty will back up such use. Officially entry in an "orginized speed event" voids the warranty but the will not argue about open track time use.
And when you modify your vehicle, such as a overdriven supercharger, thet can only deny warranty coverage for that item or others directly affected buy the modification, i.e. the incresed boost melts a piston....not covered, your radio goes bad, covered.
Rick /ubbthreads/images/graemlins/ooo.gif
Ron
[/ QUOTE ]
