Hi,
i have two remote servos and a balance bar
Need a bit of help working out exactly what has failed, whenever the brakes are used the fronts lock up gradually over a minute until they are on pretty solid. (pretty sure its just the front) If I then undo the vacuum pipe going into the front lockheed remote servo there is a hiss of air and the brakes free up again.
Is this a failing servo, or does anyone know if this can be fixed with a repair kit. not sure which brake servo's I have except they are lockheed, any easy way to tell the model
I supose I can jack the car up and see if the back lock up too! But I think the fault is the same
Grant
Grant
