I never knew Loctite made so many things. This from Pegasus:
<table align="center" bgcolor="#ffffff" border="0" cellpadding="5" cellspacing="5" width="650"><tbody><tr valign="top"><tr><td colspan="5" bgcolor="#66ffff">
Some of the most popular Loctite products are now available in solid QuickStix form. QuickStix compounds are clean and convenient. No more sticky squeeze bottles leaking all over your toolbox or workbench. There is virtually no waste when using QuickStix. A single stick will last a very long time. Hint: Don't try to pull the cap straight off. Use your thumb to push it off from the side. It's a lot easier that way and it only takes one hand.
</td></tr><tr valign="top"><td class="small" align="center" width="20%">
Loctite QuickStix 248 Medium Strength (Blue) Threadlocker - Medium strength formula (similar to Loctite 242 liquid) allows fasteners to be disassembled with hand tools yet prevents loosening under normal circumstances. 19 gram stick.
$21.99</td><td class="small" align="center" width="20%">
Loctite QuickStix 268 High Strength (Red) Threadlocker - High strength formula (similar to Loctite 262 liquid) is for locking studs and high strength bolts. Heating the fastener may be required to allow removal without breakage. 19 gram stick.
Loctite QuickStix 668 Retaining Compound (Green) - Retaining compound bonds and secures cylindrical slip-fit and press-fit assemblies with up to a 0.010 inch (0.25mm) gap between parts. 19 gram stick.
$27.99</td><td class="small" align="center" width="20%">
Loctite QuickStix 534 Hi-Tack Gasket Dressing - Helps seal all types of gaskets as well as o-rings and screw threads. Also holds gaskets in place during assembly. Resists gasoline, oil and antifreeze. Does not get brittle. 19 gram stick.
$7.99</td></tr><tr valign="top"><td class="small" align="center" width="20%">
Loctite Freeze and Release, 400ml Aerosol - This unique spray instantly chills rusted parts. The resulting thermal shrinkage cracks the layer of rust between the parts, allowing a special penetrant to wick into the joint. Parts can typically be disassembled after just a few minutes.
$9.99</td><td class="small" align="center" width="20%">
Loctite Chisel Gasket Remover - Spray it on any metal surface and let it work for 5 or 10 minutes. The foaming action softens and breaks down gaskets, sealants, paint, carbon deposits and baked-on grease and oil. Residue scrapes off easily. 18 oz aerosol can.
$12.99</td><td class="small" align="center" width="20%">
Loctite Maximum Strength Headliner Adhesive - This spray-on adhesive bonds foam rubber, carpeting, fabrics, plastic, metal, and rubber. Great for heat barrier cloth. Bonds in 30 minutes. Reaches full strength after 24 hours. 16.75 oz aerosol can.
$11.29</td><td class="small" align="center" width="20%">
Loctite Hi-Tack Gasket Sealant, 9 oz Aerosol Can - This is the aerosol version of the QuickStix 534 Gasket Dressing shown above. Has all of the same uses and performs just as well. For some applications, the solid version is more convenient. For others, an aerosol may be preferred.
$7.99</td></tr><tr><td colspan="5" bgcolor="#66ffff">
Jetnut All-metal Locknuts - Thread locking compounds should not be used above 300°F. Jetnuts are compact, high-strength, all-metal locknuts that retain their self-locking capabilities at higher temperatures. Available in
MS21042 Inch Sizes
and
Metric Sizes</td><td class="small" align="center">
Facet Electric Fuel Pumps and Accessories - All Facet pumps now feature rugged and reliable solid state circuitry. There are no mechanical points to wear out. Choose the compact cube style or higher capacity cylindrical style with integral filter screen.
from $44.99</td><td class="small" align="center">
New - AN920 Straight O-Ring Boss Adapters - We now stock a wider variety of O-ring boss adapters. You no longer have to try to make-do by grinding down the flare on one side of an AN union. We also stock angled fittings.
Straight Adapter
45° Adapter
90° Adapter</td><td class="small" align="center">
New - Gear Change Tool for LD200 Gearbox - Don't waste time improvising. Using the proper tool will make it much easier to assemble the gear stack onto the pinion shaft of a 4-speed Hewland LD200 gearbox. Replaces Hewland "dummy shaft" tool SK704-B. Made in USA.
$81.99</td></tr></tr></tbody></table>
New Loctite Products
</td></tr><tr><td colspan="5" align="left">Loctite® products are the secret weapon of top race mechanics throughout the world. Diligent use of Loctite thread locking compounds does more to improve vehicle reliability than anything else, at any price. Other Loctite products are just as valuable. They allow the professional mechanic to accomplish more in less time and with less frustration. Many Loctite products, such as anti-seize compounds, also reduce the chance for damaged parts during assembly and disassembly.Some of the most popular Loctite products are now available in solid QuickStix form. QuickStix compounds are clean and convenient. No more sticky squeeze bottles leaking all over your toolbox or workbench. There is virtually no waste when using QuickStix. A single stick will last a very long time. Hint: Don't try to pull the cap straight off. Use your thumb to push it off from the side. It's a lot easier that way and it only takes one hand.
Other Featured Items for the month of November
</td></tr><tr valign="top"><td class="small" align="center" width="20%"> Jetnut All-metal Locknuts - Thread locking compounds should not be used above 300°F. Jetnuts are compact, high-strength, all-metal locknuts that retain their self-locking capabilities at higher temperatures. Available in
MS21042 Inch Sizes
and
Straight Adapter
45° Adapter
