MKII Rear Clip Wheel Clearance
Louis
From the pictures the clearance between the tires and body looks too large to me. The car is at ride height (~5.5") with drive train installed. If the if the rear clip needs to be lower how to accomplish this?
Appreciate the advice!
Louis
Malcolm
on GTDs rear ride height is more 4.5 inches with front at 4 inch to give some chassis rake. No idea if RCR use chassis rake but something to ponder i guess. Lowering your ride height will close that wheel to arch gap. don't forget to realign the camber etc if you do!
RECOMMENDED SETTINGS
Camber Angle
Front 0.5-1.0º Neg
Rear 0.5-1.0º Neg
Toe
Front 15 minutes Total
Rear 15 minutes Total
Castor Angle
Front Non-Adjustable
Rear 7 – 8½º Adjusted to give
minimum toe-in change in bump
and rebound positions.
Ride Height
Front 4.125 – 4.5 inches
Rear 4.5 – 4.75 inches
Also – all of the settings and notes in this document are based on the
recommended tires being fitted to the ca
From SPF manual. And how mine sits.
Brian Stewart
Mine rides at 4" front; 4.25" rear. Not sure if Superformance uses the original style eccentric cotton reels to mount the rear of the rear clip, but if they do, they should allow at least half an inch of adjustment.
Louis
Thank You Gentlemen!
Tire size from RCR P205/50R15
The ride is set to 5.5". I will lower it to 4.5"
The rear hinge bracket that RCR built may need modification. I can grind the welds on the hinge bolt plate and flip it upside down so the hinge bolts are below the horizontal bar.
I will lower the chassis first.
Louis
Brian Stewart
Be aware that lowering the hinge axis too much may create gap/clearance issues at the front of the clip.
Louis
Dropping the ride height to 4.5 " really help the tire clearance. I will drop it a smig more to 4.25".
Rear tire size: P265/50R15
Thanks Brain. I really don't want to drop the hinge points as clearance with the carb trumpets will become an issue. Bottom of the oil pan is flush with the chassis so the engine can't go any lower.
Thank you again. Louis
Chris Kouba
Your rear tire could be increased as well. A 255/60-15 would add 1.6" in total or 0.8" to the gap.
Yep, go bigger rears. A 265 seems a bit small.
I think Lee had a typo as well and meant to say 285.
My Mk I has 295/50-15's. I forget what the recommended Avon/Nova sizes are but you should be able to find that out. Their spec sheet will give you their dimensions to compare to your 265. If you didn't want to go wider, a 265/60 or /65 might be a better fit as well.
Lee Patterson
No, I did mean 255/60-15. These cars ran on a 60 profile tire, not a 50. Yes, it's not as wide, but much taller. That is what I have on the back of mine. Matches well with the 215/60-15 front.
Chris Kouba
Sorry Lee. I hadn't seen a 255 in the past and assumed the first "5" was a missed "8" instead. What brand are you using?
