Your own eyes and common sense tells you the world is flat, and the stars revolve around the Earth. Do you believe that too?
Nice try at diversion/redirection yet again, Counselor...
But, I ain't bitin'.
Yes
Yes
It's complicated...obviously we need to pick and choose what we do, and can afford to do.
There was a time when 99% of the " experts" said the world was flat and the stars revolved around the Earth.
Doug, I believe some of the problem is not so much the water stored in the oceans - it's the amount that has found it's way into the atmosphere due to enhanced evaporation. This excess moisture seems to have caused much of the recent 'quirky' weather systems.
Well, the atmosphere will only hold so much moisture before it turns into precipitation, but there must be quite a bit of our planet's atmosphere that is arid, so there's probably plenty of atmosphere into which the relative humidity can attempt to equalize worldwide. I would imagine that the warmer the atmosphere is the more water it will hold...hence global warming is most likely causing the recent weather events to which you referred...as well as causing Obama to lie about being able to keep your medical plan/provider if you like them (had to add that for the rabid conservatives onboard, you know :dead: ).
Cheers!
Doug
Cheers!
Doug
(You REALLY don't like anyone repeatedly reminding readers of Obama's many lies, do you!)
Not really a problem for me, Larry...just playin' wit yer head epper: !
Cheers!
Doug
As I have stated ad nauseam...the beauty of the C.C./G.W. scam for its backers is the fact that A-N-Y change in the weather/climate/Earth's temp IS, according to the scam, PROOF that C.C./G.W. is happening no matter what that change may be. It's a 'no lose' proposition for 'em.
Cheers!
Doug
You're a bit late with that Doug...someone tampered with it years ago..:shifty:
Everyone knows all conservatives were dropped on their heads as infants and weren't too bright before that happened anyway...whereas all liberals have never had even the slightest head trauma and they all have I.Q.s well above 190....................right? Of course 'tis.
Not sure there is a rush to redistribute wealth eh, Doug. Have you read any of the U.N. Reports via the IPCC?
