New RCR transaxle?
Not sure this is the place to ask, but how "streetable" is a sequential transaxle for a 650hp/600ftlbs motor?
I take it that it isn't by the title "race" ?
And, does it include paddle shifters?:evil:
I don't have any experience using sequentials... but it apears to use the same clutch as conventionals and not a F1 or Ferrari setup... so it might be workable? Or I am just dreaming?
Here is an update..
The Griffin gearbox has been through some major hurdles the last 6 months.
In the design of our transaxles we try to use off the shelf parts.
The street boxes use gears from Richmond Transmissions. If you have not followed the news in the transmission business, you may not be aware that Regal Beloit sold the Richmond Gear line to Motive Gear.
This has upset the time line and postponed the date we had hoped to get to market.
We have now overcome these obstacles.
The flow of parts to Motive Gear has been slow and sporadic.
Their parts bins are starting to fill, and the part numbers we use are slowly becoming available.
It is just a matter of time and all the parts we need will be on hand to build transaxles we all have been hoping for.
In the meantime, we will continue to develop, test and perfect the transaxles.
Here are the ratios for the 4+1..
You are seeing them here first !!!
1st Gear.. 2.412
2nd Gear.. 1.636
3rd Gear.. 1.185
4th Gear.. 0.903
5th Gear.. 0.595
TOP that off with a 3.55 Ring and Pinion.
Hi Delynn,
We spoke on the phone a week or two back, I mentioned I was wondering about approx. total size of the gearbox, and where the mounting points would be? I don't absolutely need a diagram, but dimensions within an inch or so would be a big help; just so I don't build my chassis, and then not have enough clearance for your trans.
Thanks!
Kent
So, does this mean that the bellhousing will fit a twin-plate clutch afterall? I know there was talk before of using only single plate clutches due to space constraints.
