Hello,
I introduce myself, I am 65, retired, I live in east side of France close to Dijon. I am familliar with old Ford, I have sevral models like a 68 F250, a Mustang and a 63 1/2 Galaxie with a 427 65 Tunnel Port that I drive on track days. But since the Le Mans adventure in 65, I was dreaming of a GT40. I finally got one. The car is a RCR MK1 of 2008 initially built by a gentleman Thomas Rider, that was active on this forum I believe. The car was stored unfinish since a long time in UK and I purchased it from a vendor.
I have a lot of cleaning or cosmetic work to do, plus to finish the assembly of glass an a numerous of small things. A lot of bolts or steel parts need to be coated against rust. The car is equiped with a fantastic engine, a DART block 502 strocked to 347 and described in the book Fast Ford & Mustang of 2006. The gear box is a ZF.
I will give you more info after I will forecast all the rework or work that need to done.
The car was never painted, the exhaust is awfull and probably installed to go through the technical check in UK but I will put it quickly to the garbage. The engine is equiped with a Accel injection, that also need to be rationnally reinstalled, but it is a problem for me. I saw that iti is possible to load a free software to program it. The engine is running fine but I am afraid for the future and may be I will reinstall a Holley 750cfm.
For all this reason I call the car "Cinderella", because a lot of miracle will be necessary to transform it in a princess...
I already look to several post on this forum and appreciate the quality of the exchanges. I am sure that a lot of information may already answer to my questions, and also that I will ask a lot of questions...
