The Ford GT/Ricardo trans will hold 1000hp....Glenn Miller , heads of the Ford GT transaxle programme and SAE paper writer on the subject told me that the ring and pinion was tested to 1200hp.
If you have a G50 in 1st gear with the tail/shift shaft all the way rearwards , the GT box is actually shorter...BUT...it is massive from tip to stern ..it weighs in at close to 200lbs ...so 40lbs heavier but the perfromance is not in question.
6 SPEED....double and triple syncros...cable shift...and its the only big HP midengine transaxle that has gone through OEM testing in recent years in volume...
I have to have a minumum order of 4 to get a price break but currently have seven on order for Superlite Coupe customers ...so in reality they are not as expensive as you may first think
