I think that may be in the works...
JR
Anymore info on this?!?!?
JR
JR
It might have possibilities as a tri hull fishing boat.
Transmission foward of engine, between driver and passenger, transfer case there too, then fore and aft heading drive shafts to diffs at each end, rear offset from centerline to accommodate the drive-shaft being adjacent to the engine block . Grazino has off the shelf parts, as they already make them for big name Italian 4WD cars. Their website is rather spartan, but there are a few PDF downloads, that illustrate the customer car, some examples of which include Lambo, McLaren, Ferrari, etc. A photo of the car, and of the mechanical systems that they make for that model are illustrated on each page of the muiti page documents. Even the gear ratios are given.I believe the Grazino transmissions that Fran uses has the FWD output shaft already, The engineering exercise is getting a drive-shaft past the LS engine.
I know what you mean...the rear of this silly car is actually reminiscent of the rear end of my boat..except for the outdrive where the center bulge is on the car. The outer bulges look just like the corresponding bulges on the rear of my hull...under the rear platform. I DO believe that Fran will have better taste in consideration of the next RCR...
If the angle of the photo were lower, it would be easier to see the similarity of the boat rear to the car...I just don't have a good photo of the rear of the boat from lower, such as when out of the water.
I was just revisiting the first pages of this thread, and could not help but see the similarity to some boats, like mine...What a laugh! Jennifer
RCR is already starting in the off-raod market...how bout an articulated?
https://www.youtube.com/watch?v=CeCkCrcso98
This vintage GM film for AGL-4 is really interesting
GM's AGL-4: Corvair-Powered Experimental Vehicle | GM Authority
Opposite end of the spectrum but if you want to get into the absolutely massive Jeep world and make a lot of people very happy...
