Roaring Forties 66
Stripes painted and removed from the booth for the last time :thumbsup:
Had great pleasure in ripping down the booth.
Clayton
Clayton,
Your work on the small NACA ducts (post #107) inspired me to make one with a round outlet.
See my post #103 on page 6 of "Tornado GT40 in Texas".
-Bob Woods
Looking bloody good Clayton...nice colour yellow too.
Thanks Jimmy
Yeah I really like a strong yellow, with a hint of orange when the light fades.
Clayton
Kudos to you Clayton. Your shut lines are very impressive.
Thanks Brian
That definitely took some time to get right.
Clayton
Clayton,
-Bob Woods
Thanks Bob
Your ducts look great.
Clayton
Before I continue with the final assy, the old man and myself had started building an eight barrel injection for the next engine. Its still not finished, but here's a few photos of it so far.
Started with a weber manifold and decided to go for a clean look.
Each TB started as a billet of S/S, it will have the injector and throttle shaft housings welded in.
The ram tube is threaded to the TB.
Clayton
Also wanted to run a single fuel rail down the centre.
Took a lot of time to get the angles and heights right.
The twin rods under the fuel rail will be the throttle linkages, both pulling inwards.
Clayton
Throttle bearing housings tacked in place, they will be bored out once welded. Fuel rail ready for welding.
Clayton
As you can see from the previous posts, we had quite a lot of failures with pressing the ram tubes.
We had done this before, but not as long or in S/S.
The tubes are 2" 316 s/s and wanted to put in a taper over its length with the largest bell as possible.
Had to put them into a sleeve with the same taper so the tube wouldn't bulge under all the pressure.
Clayton
To stop the bell from splitting, we ended up annealing the tube and pressed it a bit more.
This is the maximum we could get out of them. We tried lots of other ideas, but nothing worked.
Tubes were then internally threaded to suit the TB.
Clayton
Ram tubes and fuel rail fitted.
Clayton
Start of the linkage system. The alloy block has two small gears so that the shafts rotate opposite to each other.
Part of the idle stop bracket, each TB will have a separate linkage to the centre shafts.
Playing around with some mesh screens for the look.....
Have made some more progress with the linkages, but no pictures on hand.
Clayton
Now back to the final assy.
The water pipes were covered in two layers of exhaust heat wrap. (Tried three, but wouldn't fit)
Wound one way then the other to try and keep air gaps to a minimum.
Then used some large heat shrink to hold it all together.
Engine pipes finished as well.
Clayton
Clayton,
To save me a bunch of time, from now on just assume that every one of your posts will elicit the response "fantastic", "beautiful fabrication work", and "great ideas" from me, and I won't have to respond to every post...
-Bob Woods
Bob, +1
Clayton, incredible work on that injection system and coolant tube. You and your pops have some incredible skills. Really nice stuff...
David
Clayton,
-Bob Woods
Thanks Bob
Really appreciate the support.
Clayton
Bob, +1
David
Thanks David
If I knew or done a fraction of the stuff he has, I'll be a very happy man.
Clayton
Main water pipes fitted.
There's an O-Ring around the tube which slots into a groove in the bracket.
Helps to seal and reduce rattles.
Clayton
Lights fitted, ready for wirings.
Clayton
