Rod C's Ohio RCR40
Fuel Fillers & Caps - I pulled my dash out to complete "all" of the work under and around the dash before a "final" fitment of the dash. We all know nothing is "final" and "all" of the work is never finished. Most days I take 3 steps forward and two back. If I have not redone so much I would have this car pretty much finished. Oh well, we enjoy this stuff I guess.
I figured I better get my fuel fillers installed next. I have started the car by running off of a gas can. Putting actual gas in the gas tanks is critical to getting the car on the road. This was pretty straight forward. I mounted the front clip and the spider, getting both positioned where I want them. I then set in the fillers, positioned in the center of the front clip holes, made sure everything opened without contact & screwed them down. For filler tubes I used 2 45 deg rubber filler tubes and a steel straight section on both sides. I had to trim the legs of the 45 deg tubes to get everything to fit correctly. Good news - I did not cut any of the too short, so that is a win. A few pics.
IMG_2297(3).JPGIMG_2298(4).JPGIMG_2302(3).JPGIMG_2292(3).JPGIMG_2295(4).JPGIMG_2289(3).JPGIMG_2304(3).JPGIMG_2305(3).JPG
Randy Folsom
View attachment 151887View attachment 151886View attachment 151884View attachment 151889View attachment 151888View attachment 151890View attachment 151883View attachment 151874
Good to see you making progress.
With all of the bits and pieces removed from the chassis, I flipped it over and sanded the bottom and what may be considered wheel wells with 80 grit. This roughed it up for paint adhesion.
View attachment 138415View attachment 138416View attachment 138417
I then painted a coat of acid-etching primer and 2 coats of "Raptor" epoxy bed liner over everything I sanded. I used brushes and rollers rather than spraying. It seemed to go on well. The primer was a bit thin and runny while the raptor material is thick and sticky.
View attachment 138418View attachment 138419View attachment 138420
I used two bottles of the raptor material & have two left (bought a pack of 4). I need to cover the front radiator mount sheet part and the rear diffuser. I will also likely coat the backside of the firewall. I may use any remaining to undercoat the rear and front clam shells.
Now I wait for the 7 day cure.
I am not sure if I will paint the top side of the chassis. I will see what it looks like when I flip it over. I will dynamat the cockpit to help with noise and temps.
I will work on the fuel tanks while the epoxy cures.
Rod,
Did you use an adhesion promoter, also what brand of primer?
Jeff
