A lot of recent activity on springs lately got me thinking about my tire to body rub slight issue (outer/upper tire edge) and figured a new thread on this topic may help to condense this info versus piggy-backing within someone's build thread.
My body inner wheel lips appear cut back appropriately, my ride height is about right and I have increased my shock settings from 7-8 to 12-13 click range. I have noted that on the rear I'm running out/low on rear spring compression - the springs are pretty bound up, not much more turnbuckle adjustment left. I have the "stock" supplied shocks/springs and do not use the front lift kit. I have about road 1,800 road miles at this point. I'm getting a little tire rub on all four corners at the upper-top areas of the body wheel openings. I guess I could raise the body height further, but then the wheels wouldn't sit as nicely within the body wheel openings as they do now.
Can anyone give me a drivers opinion on their spring swap-changes or other areas that I need to look at. I know that several have swapped springs, but some are still under build and may not have many/any road miles yet. All opinions are welcome though - road-track-completed or not cars - Manuf. size and part numbers? or should I just connect with Fran/RCR.
Thx - Mike
"Quotes:
"Let us know how the 750 lb springs look. Are you using 7" - 750 lb? I'm getting ready to order mine and I want to see examples before I order. Your transmission is heavier than mine? How much more weight? I'm coil bound too. "
If you look at the picture in post #382 you can see that I am almost out of travel with the stock 650lb spring. With them in the picture as shown I still don't have enough ride height. I and others have elected to go with 8" springs instead in the back. The Ricardo is just over 200lbs I believe. It might be 20lbs heavier than the Graz but I'm just guessing. Quote"
Thx - Mike
"Quotes:
