Well Fran, I haven't made it "public" yet but the goal I have set for myself is to get it to the fall Willows Springs COCOCA shelby club track day weekend in October 2012. That would require getting the car running at least a month ot two before that and finding a good place to do brake ballance, basic setup, gearbox/clutch run through, water/oil leak check, electrical checkout, yata yata yata.
Hopefully I will be done with the body mods, door fitting, and final body mounting in the next month or so. Then on to the remaining engine room work, exaust primarily, and oil cooling, ign system, gear change cable, throttle cable and some other small stuff.
Last will be the electrical system in the spring.
As you well know, working out the bugs is time consuming, but they can be kept to a minium by doing things right the first time.
