Quick update, work done since is the fans are now fitted as is the rad, I made up some small brackets to push the fans tight to the rad and also its bolted to the panel top and bottom as I thought one fixing may not be enough?
So next was the brake pipes, to keep the flexi away from the springs I fashioned some small brackets as a pinch in the spring is an IVA fail I understand and not something I would want to test!!
Does anyone use anything other than cable ties? I notched the bracket so they cannot slip but not sure of they look the part, works ok though, maybe a bit OCD??
So that's brakes and clutch all done, need pads then will fill and test, so air-con (see my other post re some help needed in that area) , I made a bracket to hold the air-con rad then decided the aluminium was too small then decided the to part was too narrow so made the whole thing twice, still jobs are always easier second time round !!!
Now its wiring loom, did people put the engine in first then wire to that? Just no real reference points to start from, am doing the front loom first as that's smaller,
Will do more pictures as I wire, lord help me, cheers
