Trev,
You raise an interesting point. Where do you find, or what type of drill bits are worth getting or having in the shop. I used a Drill Docctor for a while until the grinding wheel stoped putting the right angle on the bits.
They say they won't pick up the chassis and I don't see why should spend £300+ to get the chassis to them.
Hi Trevor,
While you’re at the mock-up stage you ought to look at how the front pipes are being located. Its not good build/engineering practice to have a the pipe supported by the inner front bulk, especially if there is no seal etc to prevent fretting between the copper pipe & aluminium bulkhead panel. Over time this could lead to failure.
Regards
Andy
Trevor
PLEASE READ THE BUILD MANUAL.
Chapter 8 step 17
Andy
...wrap loft insulation around the two pipes
Ahh, just saw your post Alan.
