hmmm - interesting this one...
I initially figured that there might be something in the 'dia' being important, but now I'm not so sure.
My figuring was that, let's say an engine produces 500ftlb of torque, if you dump that across a clutch that's half the diameter of another one, then the smaller clutch with efectively a shorter (clutch radius) mechanical advantage will present less of a load to its output (trans input) shaft....
However, I then thought about the initial figure of 500ftlbs and then figured that this measurement IS SPECIFYING the diameter already, i.e. 12". so having a 6" dia clutch is no difference because the 500ftlbs becomes 1000 half-ftlbs...? - is this correct?
Apologies Fred for the thread drift! - I hope you manage to sort your gbox soon and if you do get an upgraded unit, you'll not regret it I'm sure...
So the theory of a smaller multiplate clutch softening the torque to the trans probably goes out the window...
I should also say that I never thought that the 'snatchy' nature of the metallic multi-plate was an advantage, it's just the nature of most units. If you break traction, it becomes irrelevant because measured torque levels would then be lower anyway. When Roy's original shaft broke, we were hard on the gas in about 4th/5th gear approacing Fordwater at Goodwood. There was a couple of bangs, (each time we lifted) and then on the third bang, the shaft sheared. Looking at it afterwards you could see from the cross-grain where the initial couple of bangs had probably partially craked the shaft, as there was a slight polishing sea-shell like look to two segments and when it finally broke a couple of laps later, the final section was just a dull grained area...
Still can't quite understand though how Rodger's 'std' UN1 quill has not broken??? - Of course he might be trying a 'sneaky-pete' (read Malcolm
) and maybe he's actually fitted a DB conversion already that we are not aware of?.... No, probably not....
Anyone else...
Sorry for the thread drift Fred, if you do get an upgraded unit I'm sure you'll not be disappointed...
