Water Pump
Brian Magee
For Sale
This is a standard Windsor water pump that has had the front cut off and machined flat and a freeze plug fitted into the hole. It has new water pipes fitted, one blanked off. Starting point for your conversion to electric water pump.
£45.00 +p&p.
Brian.
JimmyMac
Brian,
Check out the billet timing covers by Garrett Machine - Lebanon OR.
www.garrettmachine.com
I am using one on a Dart 302 block in conjunction with a remote 55gals/min Mezier series 300 pump with twin outlets. This frees up a lot of space between engine front and the bulkhead. It also looks neat.
JimmyMac
Mike,
Superb.
I ordered by telephone and Mike delivered the part in four days to the UK.(he had the Ford casing in stock)
When I recieved it, I was pleasantly surprised by the quality of the machining and fit - Mike Garrett's work is a rare find these days and I bet he could probably make anything we need for a '40 out of billet stock.
If you are thinking about a cover, do your homework regarding the layout of any pulley brackets to keep the plate uncluttered.
