Hi Guys,
I would really appreciate some experienced help in getting my CAV GT40 running well. It is fitted with a 347 Boss Ford Crate engine running with 48 IDA Webers and MSD ignition and on NGK BCR8ES plugs. The symptoms that I have are that the engine runs smoothly on idle but on (very) small throttle openings the engine backfires through the exhausts - suggesting that it is starting to run lean? The top end performance seems fine.
The carbs are set with the following jets:
Idle 70F10
Main 135
Emulsion Tube F7
Air Correction 120
Choke Size 37
Can anybody tell me if these settings seem about right? Thank you!
Idle 70F10
Main 135
Emulsion Tube F7
Air Correction 120
Choke Size 37
