flatchat(Chris)
btw I do like the idea of making oil guards so as to directly observe the top end valve components. regards Dave[/QUOTE said:You can buy them ready made for adjusting solid lifter clearances .
http://www.summitracing.com/parts/mrg-1015
Bob
I have been reading this thread with interest, I don't feel I have much to give, but a lot to learn here. Basically we are talking about the possibility of 'valve bounce' and it's consequences. Since I just converted my engine to hydraulic roller lifters and am still in the first couple of hundred miles, I am listening to the engine carefully and will make periodic examinations of the valve stem markings etc. So far I have only taken her up to 5000rpm and all seems well. On the way to mot test I heard a short period of squeaking noises when I slowed off the motorway. I put down to pushrod/guide interaction and checked and found some with shiny marks, but no squeaking since then, pushrods are hardened.
My major components are all matched Edelbrock so I don't have any obvious worries, just being careful.
In the past, my mini Cooper engine was limited by valve bounce, I only did it once and it was clearly audible and the engine stopped accelerating so I didn't rev to that point again. Maybe not enough power to break the valve train but it was obvious.
Summing up I have a couple of thoughts / questions
1 Would we normally expect a period of valve bounce that was able to cause damage to be audible?
2 Are roller cam components (i.e rollers and pins) more susceptible to damage due to over rev compared to flat tappet components?
regards
Dave
