Just a few photos showing progress made so far.
I have cut a hole in the front bulkhead to allow the pedal box to move forward by about 2 inches. this gives a little more leg room.
Wiring started and also Terminator x wiring started.
Hydraulic lines fitted and air con lines fitted.
All done on a trial basis before riveting panels as easier that way to cut holes ect.
Gear change mechanism now made and fitted.
instruments and switches fitted to dash.
I decided to cut out the panel that instruments fit into as it had provision for only 3 gauges angled to driver and i wanted more....
so replaced with alloy panel covered in fake carbon cloth.
and extended down over switch positions.
relays and fuses positioned. going to have a removable panel in spider for access.
Jerry
Jerry
