I've owned and restored a couple of cars with aluminum body work. I can tell you that aluminum oxidizes just like steel, and it's just as prone to rot. It needs to be shielded from the elements in the same way.
Our GT40s are rarely used in the same way as a typical road car, many folks wouldn't take out their GT40 in the rain for example, which is probably a smart move all things considered. I tend to drive my sports cars, even in the rain, and make lots of short trips around town. HomeDepot is a common run. Given that, I had to have some corrosion protection/resistence and that's why I bought a CAV in the end (stainless chassis). I suspect a steel or aluminum chassis would have been equally as good (in some ways perhaps better) provided the surface was adequately protected from the elements.
Powder coating seems to be catching on with the body-on-frame crowd wherein the chassis is fully powder coated. After having some parts of my GT40 powder coated, I'm very impressed with the toughness of powder coat. It's very durable and highly resistant to scratching or chipping. I would definitely get a steel or aluminum GT40 chassis powder coated before bolting the components on.
As far as fasteners, anywhere you don't need a high strength bolt stainless works pretty well. Stainless can gall pretty easily, so, anti-seize is a necessary thing to use. Obviously, suspension components, CV axle bolts, head bolts, etc. should all be high strength bolts, either Grade 8 or 10.9/12.9. I've looked and looked and it's difficult to find 10.9/12.9 metric bolts which have been plated. The vast majority are just black oxide finish, and this tends to rust over time, which is a drag. If anyone knows of a good supplier of plated 10.9/12.9 metric fasteners I would love to hear about it!
